LightClock displays the time on the LED rings and LCD screen.
Time can be adjusted using the LCD shield buttons.
LightClock uses the Adafruit Chronodot which is a battery-backed RTC so it doesn't loose track of time when it's unplugged.
The case design sucks, it needs to be redone. in the meantime, a little crazyglue will prevent it from falling appart.
Details
This was initially the base of a workshop to introduce the Arduino to a bunch of friends.
I've listed ideas for future features in the Readme on Github...
Components
1×
Arduino Uno R3
http://www.adafruit.com/products/50
1×
Chronodot
http://www.adafruit.com/product/255
3×
NeoPixel LED Rings
http://www.adafruit.com/product/1586, http://www.adafruit.com/product/1643 and http://www.adafruit.com/product/1768
Just added a couple of OpenSCAD files for the PIR sensor and the buttons that I will use for the master on/off switch as well as the PIR override pushbutton. Also I modified the LCD shield file to include a version of the shield without the stacking headers and a version with them. It's all on the PIR branch in Github.
I've just created a new branch to add a PIR sensor to the clock. it's used to light-up the clock for some amount of time (currently 1 hour) when it detects movement, otherwise turn all LEDs and LCD screen off. Next is a button to override or lock the on/off state.
The PIR sensor and button will probably replace screws as "eyes" of the clock, when I redesign the enclosure.
