The brain is alive!
A project log for Audio Cube
An Audio Cube (Dice) that can audibly signal which side it has landed on.
david-wattsDavid Watts 06/02/2015 at 17:502 Comments
Finally the smd prototype is alive and working, better than I expected at this stage. More problems in the schematics became apparent, hence the jumper wires.
Still more to do but I am please with the progress so far. Next I need to get it into a rollable format.
davedarko wrote 06/02/2015 at 18:01 point
I have four words combined to a question: Hot glue strain relieve?
David Watts wrote 06/02/2015 at 18:04 point
Thanks mate, definately going down that route. I may go for an acryllic shell with some silicon caulk to dampen the impact from rolling, possibly sugru.
