1Environment setup
For the simulation version (proj_sim in github repo), Keil free version (4kB limited) and gcc toolchain are need.
For the hardware version (proj_mb in github repo), GNU assembler and make tool are needed, (Ubuntu 16.04 is used but not mandatory, sudo apt-get install build-essential).
To calculate the hash value of a word name in assembly code, there are two elisp functions that can be used in Emacs.
2For Mickey Board (some links are in Chinese only)
1) Buy a Mickey Board (https://item.taobao.com/item.htm?spm=a230r.1.14.1.1ff67ad2Sr20a7&id=546117969332&ns=1&abbucket=20#detail), switches, case and so on, assemble them into a Keyboard. The assembly method can refer to GH60.
2) Generate keyboard layout file using TKG (https://tkg.btsmartshield.com/)
3) Generate BACK hex, run make under the proj_mb,back.hex can be found under proj_mb/_build
4) Generate firmware zip by uploading the layout binary code and back.hex, upload the firmware with nRF Connect App on iOS or Android.
3For simulation (may be broken in recent version as we don't test for simulation)
Open the Keil project in proj_sim, Ctrl+F5 to start debug session.
Input/output would be In the UART window.
Thumb2
