Going forward with the Hat version
A project log for Single-cell Li-Ion Powered UPS for Raspberry Pi
A simple yet complete UPS solution for most Raspberry Pi embedded applications, using a single-cell Li-Ion Battery.
bud-bennettBud Bennett 07/08/2017 at 18:460 Comments
New Information:
I'm editing this log to reflect some new testing information. I received 2 purple Efest 14500 Hi-discharge batteries yesterday (2017-07-10). When I put them to the same testing as the other batteries I noticed that something was wrong -- the battery holder started melting at the minus terminal. Apparently, the crimped connection at that terminal had become higher resistance and causing a lot of heat to build up at that junction. After I replaced the cheap Chinese battery holder with a similar cheap Chinese battery holder I repeated the testing on all of the batteries. The new results are contained in this log. I must note that the MPD battery holders are probably the ones to get -- the contacts are a single piece of flat metal that insert directly into the PCB holes -- no chance for high resistance connection unless the contact tension is weak. And I'll bet that the plastic will withstand higher temperatures. You get what you pay for.
PaulV and I have hashed out an agreement on the "Hat-like" UPS. He wanted the UPS to provide at least 3A @ 5V. I did not see any reason to provide more than 2A @ 5V. He won the argument and we are proceeding with the Hat. I've updated the log that deals with the Hat, so see that log for reference.
There are a few restrictions on the battery if you are going to provide that kind of current. I performed a series of experiments to see if any of my batteries would be able to provide more than 2.5A. Here's the results:
When the booster is providing 3A @ 5V from the battery near exhaustion (2.75V) the current drawn from the battery will probably exceed 6A. Therefore you will need to get a battery that is rated above 6A continuous discharge current ( the "purple" Efest 14500 IMR battery is rated for 6.5A continuous, and 9.75A pulsed.)
There are a couple of take-aways from this. The type of battery that you intend to use is a big factor in the UPS performance. If you need the UPS to provide high currents then it would be wise to obtain a battery that uses IMR chemistry and IS NOT PROTECTED. If your load is less than 1A @ 5V then almost any 14500 Li-Ion battery will do the job.
The higher load current forced us to employ a poly fuse with higher current/voltage ratings, and a bigger footprint. The UPS Hat version PCB has been ordered from OSH Park and should be back from fab in a couple of weeks.
