gsm_status_v4.inoSoftware (sketch) for Arduino Nano.x-arduino - 15.62 kB - 06/06/2017 at 09:08 |
IMAG0644.jpgCompleted PCB, with A6 GSM/GPRS module, Arduino Nano, and an optional serial-to-USB adaptor for the debug interface.JPEG Image - 2.41 MB - 06/06/2017 at 10:14 |
IMAG0646.jpgBottom view of PCB. Note that this version of the PCB uses different pin numbers for the outputs from the Arduino. Check the Fritzing diagrams for the correct layout.JPEG Image - 2.02 MB - 06/06/2017 at 10:19 |
IMAG0645.jpgTop view of PCB. Note that this version of the PCB does not include the optional pull-down resistors and capacitors on the transistor gates.JPEG Image - 1.75 MB - 06/06/2017 at 10:16 |
Gates 170603.fzzFritzing files for circuit diagram and PCB layout.fzz - 32.63 kB - 06/06/2017 at 09:06 |
Gates 170602_etch_silk_top.pdfTop view of PCB.Adobe Portable Document Format - 111.93 kB - 06/06/2017 at 10:23 |
Gates 170602_etch_copper_bottom_mirror.pdfBottom view of PCB.Adobe Portable Document Format - 7.12 kB - 06/06/2017 at 10:24 |
