• Revision v1.1
    Thomas Gonnot • 12/31/2017 at 22:26 • 0 comments
    I finally had the time to make some changes to the project. The major difference is the switch to a STM32L071KZU6 MCU, comming in a different package. Other differences are the add of a decoupling capacitor and the 180° rotation of the battery connector. I removed the old files from hackaday, and will put the new ones once I have more time again. The files are available from the CircuitMaker project page.
    I already ordered the PCBs, but this time with a ENIG finish and 0.8mm thickness. I'm expecting to get them around mi-January.
  • Needs a revision of the PCB...
    Thomas Gonnot • 10/11/2017 at 19:56 • 0 comments
    After upgrading the microcontroller to the STM32L031F6P6, I realized a very unfortunate fact.
    Although the STM32L011F4P6 had the BOOT0 pin shared with the PB9 input, the new chip has only BOOT0 on this pin. Therefore, a press on the power button would not be detected. Although the design can still work with 2 buttons, I would like to have 3 buttons design.
    On another note, ST also sells modules that includes both MCU and Bluetooth functionality, and if I can make is simpler that way, I will.
    Next update in ... I don't really know...
  • It lives, and also switching MCU
    Thomas Gonnot • 10/11/2017 at 16:49 • 0 comments
    I finally had some time to troubleshoot the programming issue that I was having, and realized that the reason I wasn't able to connect to the chip is because the PCB i was using to hold the pogo pins had a defect and the ground plane was missing somehow....
    Jump wire in place and now it works!
    I am also planning on upgrading the chip to a STM32L031F6P6, for an increase in SRAM from 2K to 8K. The device should still be able to function with the originally intended chip, but bigger SRAM would allow to have the full display in a buffer in the MCU and allow more complex operations. The chip is pin-to-pin compatible, so there will not be a difference in the PCB design. The increased Flash will also allow the storage of few graphics on the MCU rather than the SD card.
  • Need to find the time...
    Thomas Gonnot • 09/09/2017 at 15:11 • 0 comments
    Just a quick note to say I haven't abandoned this project, but it is on hold for now, until I find the time to get back to it.
    That being said, I ran into issues: the chip isn't recognized by the STLink for some reason. Whereas is it a defective chip, the pogo pins for the probe, or just my design remains uncertain.
  • Prototype ready!
    Thomas Gonnot • 07/14/2017 at 16:47 • 0 comments
    The components arrived and are soldered! This time no screw up.
    I added the pictures to the gallery.
  • First fail
    Thomas Gonnot • 07/03/2017 at 18:08 • 0 comments
    So I received all the components, and used my reflow over (toaster) to solder all of them. Unfortunately some shorts appeared, and in the effort to fix it, I overheated the ePaper connector. Everything works fine except I can't connect the display...
    Will get another batch of components and try again later in the month.
  • The PCBs arrived
    Thomas Gonnot • 06/22/2017 at 13:07 • 0 comments
    I finally received the PCBs! SeeedStudio Fusion service have a descent quality actually, less than $5 for 10 boards, without shipping. Come to think about it, I should probably have ordered an ENIG finish, but this will probably do fine.
    Here is a picture of both sides:
  • PCB in production
    Thomas Gonnot • 06/10/2017 at 02:36 • 0 comments
    I just sent the PCB to be fabricated by Seeedstudio. I also received the stencil today.
    I added the BOM as a CSV file. Quick note, all of the component except the microcontroller are available from Digikey. Other websites like Mouser have the microcontroller, but miss other components, although equivalence might be available. The BOM is also available on Octopart at https://octopart.com/bom-tool/qB575L1h.
