Light switch (hit note)
06/10/2017 at 20:29 • 0 comments- Light switch (hit note) includes: electricity supply 5v 1a, Arduino pro mini, Nrf24l01, relay 5v10a, relay 3v3a.
5v10a relay x 2
3v3a relay has error handling function for Nrf24l01. When Nrf24l01 is having problems, relay 3v3a will turn off Nrf24l01 3 seconds, then turn on Nrf24l01 again. Because Nrf24l01 has no restart pins.
Light switch (precarious)
06/10/2017 at 19:59 • 0 comments- Light switch (precarious) includes: electricity supply 5v 1a, Arduino pro mini, Nrf24l01, servo.
Use two servos to control the lamp . Or manual user controls.
The advantages of this type are: when the electronic equipment is damaged, the power switch is manually controlled.
video: light switch
Water heater
06/10/2017 at 19:33 • 0 comments- Water heater includes: electricity supply 5v 2a, Arduino pro mini, Nrf24l01, relay 5v30a*4, BUZZER.
The device uses 4 5v30a relay. 2 relay on or off for 1 wire.
The default is to turn on, when starting to power up Water heater.
Water heater can turn on / off manually, so do not write data on / off to EEprom.
Because relay to turn on / off the large electricity(Cause strong electromagnetic waves), should 328p chips crashes. I temporarily processed by: using 2 chips. If 1 chips is crashes then the other chip will handle. The normal chip, will restart the chip crashes and return value to it. That way, it gave pretty good results.
Air-conditioner remote control
06/10/2017 at 19:12 • 0 comments- Air-conditioner remote control includes: CHUNGHOP.K-1028E chip, Arduino pro mini, Nrf24l01, BUZZER, Adapter 5v 2A, Button.
CHUNGHOP.K-1028E chip (Multi-function air conditioner control)
Controls all types of air conditioners.
Install for "air conditioner remote control"
Fire alarm
06/10/2017 at 18:58 • 0 comments- Fire alarm includes: electricity supply 5v 1a, Arduino pro mini, Nrf24l01, MQ2 sensor, BUZZER, Button.
The box is the box of 5v2a source.
Alarm and Fire alarm
06/10/2017 at 18:49 • 0 comments- Alarm and Fire alarm includes: mobile phone Itel IT2180, Arduino pro mini, Nrf24l01, relay 5v * 5, PIR sensor, MQ2 sensor, Adapter 5v 3A, BUZZER, Button. "Alarm and Fire alarm" Work for 8 hours when power is lost.
- "Alarm and Fire alarm" also features: "Guest alarm". This feature is controlled directly on the device, when the alarm is off. (The device will sound when guests arrive)
- "Alarm and Fire alarm" uses phone batteries when power is lost.
- "Arduino pro mini" will press the buttons on the phone. Advantage is: cheaper price (mobile phone is 9 usd, sim 900a module costs 16 usd). Using cell phones we get: batteries, monitors, keyboards.
modul relay logic
Enter two numbers in the phone book. Used to call when an alarm occurs.
After completion. Box using PVC sheet.
Enter the program code for "arduino pro mini", enter the phone book. Then close the box cover.
Self-protection feature of alarm device when power is off.
​Central Controller
06/10/2017 at 18:25 • 0 comments- Central Controller includes: Ethernet W5100, Arduino Mega 2560, Arduino pro mini, Nrf24l01, Adapter 5v 2A, BUZZER, relay 3v3a, Button.
The central controller is responsible for controlling and managing all equipment.
Central controllers use wired networks to access the internet.
When the central controller encounters a problem, it will automatically restart.
3v3a relay and capacitors have a central controller reset function. It's like pulling out the power cord and plugging it in again. Because Nrf24l01 has no restart pins.
The box is made of PVC sheet.
Tiendo
