Thanks to the kind contribution of the donors, we just reached the goal of the campaign for financing Phase 1B “Fast simulation bus”.
The PCB (Printed Circuit Board) design is currently being finalized, as soon as we have reviewed it, we will publish it in our GitLab repository. This last phase was of fundamental importance as we could test the correctness of the design, paving the way for the next campaign.
We got through the hardest parts with regards to the Research and Development choices. We past the uncertain ground with its many open challenges and many solutions have been explored. We also past the economical goal of previous campaigns that were quite heavy, and thanks to many people we have managed to get this far, again, thank you all!
We are now ready to launch Phase 2 “Production and delivery of five working prototypes” with a goal of 10500 Euros (around 12720 USD).
Our target is to complete this new campaign by Spring 2021, and we are working again with the patient guys at ACube Systems that will assist us in making the five prototypes.
These prototypes will be very important as they will be used to
So far, we worked with U-Boot on the NXP T2080 RDB Devkit but that is quite different to our motherboard, which is quite more complex. We have to fine-tune U-Boot directly on the final hardware, and the prototypes will be essential for this. In addition, work on U-Uoot is still required even with the Devkit in order to correctly set up the framebuffer. Right now we can access the U-Boot console in serial mode only. ACube Systems will assist us on this task.
The motherboard is designed (screw and ports positions) to fit inside the Eclipse Notebook body that the prototypes should be mounted on.
Moreover, we need to redesign the dissipation heat pipes that will be slightly different from what was originally in place for the Eclipse Notebook.
Maybe some of you didn’t even think it was possible but we are progressing. The journey is still not finished. We need you to tell about this project all around you as we need more interested people, more donations.
2021 is our year! Let’s make this project a reality!
The campaign aimed at the “Fast simulations bus” is nearly complete, and we will receive the resulting PCB design before the end of 2020. As soon as we have reviewed it, we will publish it in our GitLab repository. Here a screenshot with the PCB design currently being finalized.
our PowerPC Notebook Motherboard design screenshot from Mentor Xpedition
Similarly to what we did for the current campaign, the next donation campaign for financing the “Production of five working prototypes” will start as soon as the current campaign will reach its end. In coordination with ACube Systems, we fixed the cost of the five prototypes to 10.500 euros, and we aim at delivering them during late Spring 2021. The plan is to extensively check each prototype before building the next one so as to include fixes in each round. We will keep you updated at each step, and, finally, we will be able to provide you with photos of physical products.
We are happy to share to all the donors and followers the Board Layout of our PPC64 Notebook Motherboard!!!
The design of our board layout is meant to fit inside the Slimbook Eclipse body. The PCB Design which is currently being worked on using Mentor Xpedition.
In September 2020 we have published on our gitlab repository the Orcad source file with the latest version (v0.6) of the Electrical Schematics, you can go more deep on these board layout starting from the Orcad source.
Open Hardware PowerPC Notebook Board Layout for Slimbook Eclipse Body – TOP
Open Hardware PowerPC Notebook Board Layout for Slimbook Eclipse Body – BOTTOM
The tentative deadline for Phase1B is 2th November so there are two weeks left to donate the remaining 3660 euros. If we will reach the goal, the PCB with SI bus simulation should be ready by the end of November.
In this case in December 2020 we will work on production of the Prototypes together with the Prototypes Donation Campaign.
We have to give a name to the motherboard, suggestions still remain open few days more on our forum
Finally we have published on our gitlab repository the Orcad source file with the latest version (v0.6) of the Electrical Schematics.
This file is at base of the PCB Design which is currently being worked on using Mentor Xpedition. The previous version of the schematics required some updates in order to accommodate minor changes to match the Slimbook chassis internal spaces. In addition, the schematics are now compatible with the I/O expansion board and the position of the external ports found on the “Elipse” chassis model, that was kindly provided by Slimbook.
After achieving the goal of Phase 1A (thank you all!!), we have just started Phase 1B of the donation campaign targeting the “Fast SI bus simulations”, in other words, an in-depth analysis of the integrity of signals of the PCB that came out from the previous campaign.
After discussing with the engineers currently working on the PCB, we were told that publishing an incomplete and potentially buggy PCB does not have much sense, as there might be major problems that will be solved after carrying out the SI bus simulations. At the end of these long discussions, we agreed on publishing the PCB only after reaching the end of Phase 1B, when all checks will be done.
At this point we cannot fix a deadline for publishing the PCB, as the end of the work on the PCB largely depends on when we will reach the goal of Phase 1B donation campaign and when the SI simulation will help solve all electrical problems that may come up.
The tentative deadline for Phase1B is 16th October so there are two weeks left to donate the remaining 4000 euros (around 4700 USD). If we will reach the goal, the PCB with SI bus simulation should be ready by the end of November .
Around 6 years back, we started as a group of FOSS, PowerPC and Open Hardware enthusiasts, with beginning to work on PowerPC Notebook project which was designed around GNU/Linux using Open Hardware. We had very limited funding with limited skills to work. But our enthusiasm and motivation led us to reach fabrication stage for the motherboard. Finally this year we could successfully design its PCB with the help of collaborators and limited funding from donors. There were many challenges faced in this process. Since PowerPC processors have been around for more than 2 decades, but the current implementation on Notebook was difficult to take in the market. Coming to the performance in Big Endian mode is maximized in this with many software need to be patched. In future we plan to upgrade our PCB design to the more recent packaging technology for the processor. Also, with increasing collaborators, it would be possible to design more smaller and cheaper PowerPC board.
In the last PCB update post we mentioned that a new version V. 0.5 ( June 2020) of the electrical schematics is in the works. After a few rounds of internal reviews, that new version is now finally ready to be publicly shared.
The progress of donations is going well and we reached 71% of the goal.
A big thanks to all donors!
New Version of Electrical Schematics
We just received a new version of the schematics (v0.5) that raise the power consumption footprint up to 90W in order to support higher end MXM 3 video cards that may reach a maximum of 55W under heavy load. As an example, the AMD Radeon E9174 (GCN 4.0) has a TDP of 50W.
Electrical Schematic version 0.5 June 2020
We will publish in our repository this new version of the schematics ( pdf format and Orcad source) as soon as we finish an internal round of checks in close collaboration with ACube Systems, as we would like to ensure that it can be considered finalized.
PCB Design Timeline
In the next few days the engineer taking care of the motherboard design will concentrate on the PCB, as the Electrical Schematics are now stable enough.
Thanks to the donations already received, the work on the PCB design ( done with Mentor pads ) can move forward and we estimate it could be completed by September 2020. The timing is somehow unfortunate, as August in Italy is a month where anybody is on holiday, nevertheless, we will do our best to avoid interruptions.The date of publication of the PCB design will depend on the results of the internal review process once we receive it, hopefully it will not take long. The design of the PCB fit inside the Slimbook Eclipse body.
We will export the Orca electrical schematic design even to EDIF format, to make easier for new volunteers to convert it to Kicad Format. To convert from EDIF to Kicad we have found edif2kicad tools https://github.com/svn2github/edif2kicad but we are sure you will find other tools or even you will be able to create a new one
In case you are able to convert our PCB Mentor Pads design to Kicad you are welcome to do it. If you have any issue when doing so, contact us and we will be happy to provide some help.
More time for Donations
After an internal discussion, we decided to postpone the deadline of the current Donation Campaign (Phase 1A) to the 30th of July 2020.
The plan is to deliver the PCB design with the end of Phase 1A, and right after that start Phase 1B “Fast SI bus simulations” on the 1st of August with a goal of €5000 (around $5600). As a consequence, there will be no interruption in the donation campaign, it will transparently fade from Phase 1A to Phase 1B seamlessly.
We kindly ask all followers, friends, and donors to concentrate their donations before the 30th July 2020, to ensure the end of Phase 1A without further delays.
We also kindly invite any of you that is capable of technically reviewing the hardware schematics to contact us, as that will help speed up the design process, as well as improving the overall quality of the final motherboard.
You can now donate from any country thanks to Stripe Payment Gateway
Potential donors from Countries such as Lebanon and China were unable or had serious difficulties to donate via Bank transfer and PayPal. The issue is now solved thanks to the addition of Stripe Gateway among the payment methods, they applied for us a discounted rate being a non-profit organization and they charge a commission on each donation of 1,2%+0,25€ inside the EU, and 2,9%+0,25€ outside the EU.
In the last log we mentioned that a new version of the electrical schematics is in the works. After a few rounds of internal reviews and changes, that new version is now finally ready to be publicly shared.
We publish a PDF version of the schematics exported from the ORCAD software that is being used by the designer. You may navigate through the document and investigate each component, but unluckily, due to the complexity of the document some PDF viewer may be unable to correctly visualize its content, if that happens just change the viewer you are using.
After receiving these new schematics, we already requested a new round of changes to the designer, in particular we would like to raise the motherboard power consumption footprint up to 90W in order to support higher ends MXM 3 video cards that consume a maximum of 55W. As an example, the AMD Radeon E9174 (GCN 4.0) has a TDP of 50W. The idea is to obtain a new version of electrical schematics before the end of May.
If you think a TPD of 90W is too much for a laptop, I can tell you that while I am typing this post on my laptop (a DELL XPS 15 9570, released in 2018) I have attached a power meter to the power brick and the power consumption bounces between 40W and 90W (dunno why is going up and down, I have only a browser turned on). I have also tried playing some 3D games on my DELL laptop, and the power consumption reaches picks of 110W, and sometimes even higher, up to the limit of the power brick, which is 130W.
The current version of the motherboard, as you can see in the electrical schematics at pages 3 and 4 of the PDF, there are two SO-DIMM DDR3L slots that can host DDR3L non-ECC (max 1866 MT/s, PC3-14900). We opted for non-ECC modules as they are way easier to find on the market and are less expensive than ECC ones, so it will be easy to have 32GB of RAM (2x16GB), up to a limit of 64GB of RAM, if you can find 32GB SO-DIMM modules.
Thanks to the project’s supporters (here a list of donors) and in spite of the current difficult times due to the coronavirus impact on everyone’s life, we reached 60% of the goal of the current step, making us confident that it will be possible to obtain the PCB design in a reasonable time frame.
Still, we still have to raise the remaining 40% (€7600 / $8400) to reach the current goal and we kindly ask any of you to continue supporting the donation campaign.
We also invite anyone that is capable of helping us in the technical review of the hardware schematics to contact us, as that would help us to speed up the design process as well as improve the overall quality of the final motherboard.
We finally would like to stress that the PowerProgressCommunity association behind this project has the long-term goal to lower the existing barriers for accessing and sharing technological knowledge. Being able to freely share a laptop motherboard schematics will dramatically improve the current situation where access to these kinds of data is difficult for who is working in the field, let’s imagine how difficult it is for who is just approaching the topic like students and hobbyists. In addition, by stressing on alternative, non-mainstream technologies, will help spread a culture of diversity, so much important in a flattening world where younger generations don’t even imagine that a different architecture from x86 or ARM exists.
---------- more ----------
Working on U-Boot
Our NXP T2080RDB devkit boots with AMD RadeonHD video cards using GNU/Linux PPC distros. So far we have successfully tested Debian 10, OpenSuse, VoidLinux, and Fienix. However, due to a lack of involved people expert on U-Boot, we are still lacking support for video output during the boot process, just before the linux kernel kicks in. Very recently, a couple of supporters experts in this field contacted us and joined the group. Thanks to their help, we are confident to solve the current situation, and even update U-Boot from the latest sources. Hopefully, we will be able to publish a new post with some good news in the not-so-distant future.
Interview to Roberto Innocenti about our project thanks to Charbax of ARMDevices
At the end of April, thanks to Charbax of Armdevices.net, there was an interview with Roberto Innocenti, the first creator of the idea of building a PowerPC laptop and co-founder of the PowerProgressCommunity. The interview was about the laptop project and other activities carried out by the not-for-profit association. Below you may find the topics touched in the interview. We think that the interview is interesting and contains many hints on the approach we are following, even if the spoken English of Roberto is sometimes difficult to follow. During the interview one person asked about the Manjaro distro for PowerPC, and after some check, it seems that such a distro lacks a PowerPC support.
0.13 Self-introduction of Roberto Innocenti 0.45 Power Progress Community non-profit association 1.34 PowerPC notebook project 3.15 PowerPC architecture history 6.13 OpenPOWER Foundation 7.11 Why NXP CPU and not IBM 9.40 PowerPC on Linux 11.35 Linux distributions runnable on PowerPC 13:36 Future of embedded PowerPC 15:21 Cell processor interesting facts 18:27 Schematics and diagrams of PowerPC notebook project 19:31 NXP CPU specification 20:13 Upgradable AMD Radeon MXM GPU 21:02 Contribution of Power Progress Community and ACube Systems Srl 22:24 TDP, commercial usage and capabilities of NXP CPU 27:40 Supported kinds of storage 28:28 More about AMD Radeon MXM GPU 30:14 Old PowerPC MacBook performance compared to PowerPC notebook dev kit 31:41 Is Roberto Innocenti is better than Steve Jobs? 😉 32:25 People behind the PowerPC notebook project 34:07 PowerPC compared to ARM 37:35 More about OpenPOWER Foundation 40:43 Donation campaign details 43:52 Slimbook Eclipse chassis 46:50 What about small-desktop/NUC style device? 48:44 Estimated price of PowerPC notebook 51:55 Manufacturing of components 52:50 COVID-19 situation 56:23 Young people involved in PowerPC notebook project 57:11 Diversity of hardware designing, production and distribution 1:04:50 Transparency of NXP CPU 1:06:13 More about manufacturing of components and dependence on China 1:09:21 Ubuntu and Debian on PowerPC 1:11:03 Manjaro and other Linux distributions on PowerPC 1:12:30 Current phase of donation campaign 1:14:00 Potential successor of NXP CPU
We are near the 50% of the goal of the PCB Donation campaign, and we thank each of you that allowed reaching what many thought was impossible, “the key to what you do is in the heart of what you believe” (cit. by Mario Luis Rodriguez Cobos).
Like anybody else, most the volunteers, collaborators and donors involved in our project, we all have some very negative impact from the covid-19 that lead to a massive slow down of the donation rate.
On the other hand, many people are taking the opportunity of being in a lockdown at their homes to spend more time with their families, with their hobbies and to develop their aspirations. For many, it meant to spend more time thinking, developing and using Open Source Software, thanks to the freedom to run, copy, distribute, study, customize and improve their software. For others, it meant to have more time for developing Open-Source Hardware, Open Source Design of the mechanical aspects, and other important social, cultural, scientific activities, and eventually, to give them back for free to the community.
However, the financial impact of the situation meant to have less cash in our disposal, others are the current priorities in our lives.
After some internal discussions, we decided to postpone the deadline of the Donation Campaign to the 30th of June 2020, hoping that we all will be back soon on track, and meanwhile we will try to do our best to keep the project going.
Next round of the updated Block Diagram and Electrical Schematics
Since January, we have transferred to ACube Systems 8500 euros (roughly 9200 USD), so the design is in progress for a while now.
We have recently received from the engineers a newer revision of the Electrical Schematics that takes into account the recent developments, and it is currently under evaluation prior to its publication, most probably in a week or so.
Among a series of minor revisions, we have upgraded the Pericom PCIe Packet Switch from the previous model PI7C9X2G608GP to the more powerful PI7C9X2G612GP that offer 12 lanes instead of 8 lanes. This switch connects the motherboard to the Eclipse Expansion I/o Board via a PCIe, and allows to drive the Ethernet port based on the Realtek RTL8111F chip, the SD-card reader based on the Realtek RTS571x and to connect two USB3 ports.
The new revision of the schematics also brings an additional USB 2.0 Hub managed by the MicroChip USB2514 that will be connected to one of the T2080 USB 2.0 ports. To this USB Hub, we will connect the SK5126 Keyboard matrix and with an SD card reader controlled by the Realtek RTS571x of the Eclipse Expansion I/O Board and with the M2 WLAN and M2 LTE.
The Microchip Ethernet Transceive KSZ9031 is still present from the previous revision, and it is connected via the RGMII0 port of the T2080 using an 8 pins header.
A MicroSD port will be connected directly to the T2080 eSDHC controller interface.
Below the new updated Block Diagram.
April 2020 Block Diagram of the Open Hardware PowerPC Notebook Motherboard
Overall, the above mentioned changes allow to decrease the number of components in the motherboard, will reduce the production costs, as well as will reduce the debug time.
Unreal Engine PowerPC64 Building progress
Recently, new collaborators joined the ongoing activities and are helping the laptop project and other side activities in our association. As an example, thanks to these recent collaborations we have progressed in the compilation of the Unreal Engine on PowerPC 64 Big Endian, a great piece of software we are working on in order to have it running on our notebook.
Piece of script with download and build of clang
The first step is to get a clang toolchain needed by the Engine builder script. Just because a PowerPC toolchain is not available from Epic repository we have to build by ourself.
The main script that do all the job is build_linux_toolchain.sh located at the path Engine/Build/BatchFiles/Linux/Toolchain/DockerOnWindows/build_linux_toolchain.
Based on ppc64le branch this script download and build gcc 9.2.0 through crosstool-ng and then do the same for clang. Our reference version is 8.0.1 from official git repository https://github.com/llvm/llvm-project.git.
We have some problem during final toolchain copy, when gcc and clang libraries are moved to one common path (sysroot). After this action the binaries inside sysroot get a segmentation fault.
Updates on Schematics transposed in the PCB design
In February the designer analyzed the Pericom PI7C9X2G608GP PCIe Packet Switch with the direct support of Pericom staff. Now, the Pericom PCIe Packet Switch is fully tested and all the needed setup is completed, so the designer has completed the inclusion of all required information in the updated version of the schematics and is starting to unravel the PCB.
The designer has updated SerDes connections following our suggestions taking into account the notes we have provided, so a new version of the schematics is expected soon.
Arctic-Fox 27.10.1 PPC64 in our Repo
The main contributor to Arctic-Fox – Riccardo Mottola – association member of our Power Progress Community – have released the new version 27.10.1+b0 that we have compiled and packaged in our Debian PPC64repo. Riccardo says: “Session Store, code greatly improved compared to past releases, performance improvements in both the html engine as well as a new build system imported from Firefox. This release is definitely a great improvement compared to 27.9.19 right at start”
Arctic-Fox 27.10.1 PPC64 running on our T2080-RDB, that has the same processor as our future notebook.
Moved our repo to our Power Progress Community GitLab group.
We have created a Gitlab group called Power Progress Community, and we moved all our gitlab repositories under https://gitlab.com/power-progress-community. What is important to know is that all URLs have changed and any cloned repository must be rebased. If you have cloned our repositories you should update git remote origin.
Working on Unreal Engine for PowerPC64 Big Endian
We are working on a port of UnrealEngine (UE) to PowerPC 64 Big Endian. We started by forking the PowerPC64 Little Endian (PPC64le) version and we are currently trying to compile the sources. The original PPC64le port for UE 4.23 was developed by Elvis Dowson and Raptor Engineering and can be found at https://github.com/edowson/UnrealEngine/tree/4.23-ppc64le. Access to the UE4 sources requires accepting the Epic Games EULA as described in https://www.unrealengine.com/en-US/ue4-on-github.
We have modified the original scripts to compile for PPC64 Big Endian but so far we still have to solve multiple errors leading before being able to generate a working binary. You can find our fork and ppc64 branch here https://github.com/robyinno/UnrealEngine/tree/4.23-ppc64 ( to access it you need to accept Epic Games EULA). We are building the source using both a Power9 virtual machine provided by Open OSU and OpenPower Foundation, as well as on our NXP T2080-RDB development kit using Debian PPC64 SID unstable. If you want to help us on fixing the compilation errors, you can start from our UnrealEnginePPC64 Wiki, please contact us.
A screenshot of the ongoing compilation of Unreal Engine on our NXP T2080-RDB
