First dimensionally accurate model a 16 led Neopixel ring from adafruit
http://www.adafruit.com/products/1463
https://fusion360.autodesk.com/projects/neopixel-r...
Then define a body space gap with the model so you can use it as a boolean operator against the piece you wish to mount it in.
Design a test piece to test the body space fit.
Print it, low material use compared to final part, so you can afford to iterate...Be amazed when it fits like a glove the first time.
Model it directly into the target part...
Prototype your electronics.
No easier to video when in the helmet, trust me, it looks fab...
to be continued.
big_red_frog
Hi I was wondering if you could put the neopoxel stl up on thingyverse? Thanks in advance! :-)
