First step: the theory
A project log for 3D Shutdown
Autonomous shutdown with Flip-Flop RS for 3D printer.
daveDave 06/17/2017 at 14:430 Comments
The NOR:
I need to search some theory about Flip-Flop for the first step:
This is the first model you see on Google/Wiki if you search Flip-Flop SR.
The true table: https://goo.gl/w9dPSh
It's pretty easy to understand, only 2 Nor, and very fast to build, if you want, with IC 7402.
Online simulator: http://tinyurl.com/yabdpq28
The NOR with the transistors:
In this project we want to use only transistors and resistors component, and we need to go a little bit deeper inside the Nor component.
This "clickable" image is the base of what is inside the NOR component:
We can play with this schematic on the simulator: http://tinyurl.com/y7753y8x
Now we could simplified the schematic in this way: https://goo.gl/RPZZFU
Perfect, the last - simplified - schematic is a good point to start and grow up the project.
The next steps for the projects are:
Notes:
Key note is that: the circuit is symmetric.
