Hackaday.io Hackaday.io
Sign up Log in
9-24V output 36W programmable Powerbank
For when you need something other than USB output on your powerbank
muxmux
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.4k views
1 comments
14 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
2.4k
1
14
12
Team (1)
  • muxmux
Join this project's team
  • Main website
ongoing project
powerbank programmable
This project was created on 07/07/2017 and last updated 9 years ago.
Description
This is a slightly over the top project, I'm sorry to say. I happen to have a tablet computer that insists on charging from a 12V power supply, but I would like to use it for longer than the built-in battery allows. Unfortunately for me, 12V powerbanks are quite rare, expensive and just not hackerish enough. So I built my own. This powerbank has 2 regular USB-A outputs with a combined capacity of 2A, but the real fun starts with the 36W, programmable 9-24V output. You can use a little USB utility to set the output voltage. But that's just the beginning. It is programmable - not a little bit, you can literally write programs for it. It supports an easy to use pseudocode programming style that lets you blink the LEDs, turn the various outputs on and off, respond to the output current changing, time stuff. You can program it to be an alarm clock by blinking at you after a certain amount of time. You can use it as a programmable portable power supply. It's awesome.
Project Logs
Collapse
  • Playing with the XMEGA C4 ADC in the Powerbank
    mux • 07/07/2017 at 16:55 • 0 comments
    I've done some really in-depth analysis on the ADC in the powerbank, partially in preparation for the newest firmware, partially because I was just curious. I'm sure you will like this video!
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
MrAppAndCrap wrote 04/22/2022 at 03:00 • point
Very cool project, really nicely done!
What have you used it for so far?
 I am looking for a small portable device that can power my pi zero boards I leave around places. Maybe I could use some of what you have learnt here to create one? I'd need (or want to) add a small solar pannel for charging, i'd also like it so it only turns on at a certain time of the day and conserves battery / charges for the rest of it. Think it could be done with your little device here?
https://i.ebayimg.com/images/i/281283530133-0-1/s-l1000.jpg That's the sort of size I'm thinking for the solar battery supply.
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "9-24V output 36W programmable Powerbank", please tell us the reason.
Send message
Remove Member
