close-circle
How to Make a Swiss Army Key Ring
A wise way to organize your keys neatly
"Oh My God, my key chain is just a trouble! "… "Can I have my keys organized neatly? "…
If you have these questions, you just need this blog - to make an army key!
No further ado, let's begin!
DIY a Swiss Army Key
  • 6 × Key Connectors and Accessories / D-Subminiature Connectors
  • 2 × Thigh plates of the SunFounder Crawling Quad Robot
  • 6 × washers
  • 2 × M3*30 screws or M2, length depending on how thick the keys
  • 7 × M3 Nut or M2 if M2 screws
View all 9 components
View all 2 project logs
  • 1
    Prepare:
    Several keys
    2 * Thigh plates of the SunFounder Crawling Quad Robot [1]
    Several washers [2]
    2 x M3*30 screws (or M2, length depending on how thick the keys)
    ? * M3 (or M2 if M2 screws) nuts (? >= number of keys + 1)
    1 * Thick & Hard cardboard
    1 * Screwdriver
    1 * Knife
    1 * Pencil
  • 2
    Step 1: Insert the screws through one thigh
    Since I use the round-head M3 screws (5.5mm head), it sinks through the hole on the thigh plate. So I use two washers.
    Tips: Here I use some acrylic washers. If you don't have these, you can make them with a thick cardboard or cuttable plastic board [2]. Then cut the board based on the holes' size on the thigh and the keys.
  • 3
    Step 2: Put a key on one screw and a wash on the other
    It doesn't matter whether to put which on which. But remember the washer should be almost as thick as the key.
View all 8 instructions
