Improved Gait
A project log for Dogbot
A quadrupedal walking robot
Charles GalambosCharles Galambos 4 days ago6 Comments
So after a bit of tinkering with the gait parameters I managed to come up with something that works much better.   It is still a fixed gait animation without any feedback, but it is stable and robust against disturbances.  Next is to add some feedback from an IMU and the torque from the motors.
davedarko wrote 3 days ago point
cool!
Dennis wrote 3 days ago point
Very nice!!!
Josh Cole wrote 4 days ago point
Wow this is awesome progress :D nice job!
ꝺeshipu wrote 4 days ago point
I see you added pauses to avoid oscillations. But you still move the legs very fast to avoid falling down, so this is not a statically stable gait. I think you would get statically stable if you moved the body away from the leg that is about to be raised before every step — I do that for my robots and it helps a lot.
Charles Galambos wrote 11 hours ago point
It is actually doing as you suggest, the pause is it actually it shifting its weight though it isn't obvious from this shot. Have you any experience with dynamic gaits?
ꝺeshipu wrote 9 hours ago point
Ah, I see, it's not obvious.
Not really, my robots are very small and simple, and don't (yet) have any kind of sensor feedback. I did manage to make them trot, which counts as a dynamic gait, but that's achieved by simply moving fast enough that it doesn't have the time to fall. No balancing or anything advanced like that.
I know some theory around the ZMP, but I never actually used that in practice. With your motors acting also as force sensors, it seems you should be able to calculate ZMP for your robot.
