Scorpion_3_0_test_plan.docxTest plan acoording to the ISO 16750 standardsdocument - 1.04 MB - 09/04/2017 at 06:03 |
Scorpion_3_0_firmware_A4.txtA4 variant for the Scorpion 3.0 project. Check the log for more informationsplain - 42.02 kB - 08/25/2017 at 10:26 |
Scorpion_case_TOP.stlSTL file for the top side of the caseStandard Tesselated Geometry - 166.88 kB - 08/25/2017 at 10:06 |
Scorpion_case_BOT.stlSTL file for the bottom side of the caseStandard Tesselated Geometry - 117.27 kB - 08/25/2017 at 10:06 |
case print.pngBottom case file loaded in Slic3rPortable Network Graphics (PNG) - 206.05 kB - 08/25/2017 at 10:03 |
case render.pngrendering of the case in AutoCADPortable Network Graphics (PNG) - 47.87 kB - 08/25/2017 at 10:03 |
case render open.pngopen case renderPortable Network Graphics (PNG) - 59.35 kB - 08/25/2017 at 10:03 |
Rendering.jpgRendering of how I imagine the PCBs inside the case of the Scorpion 3.0. Stay tuned for the actual case design.JPEG Image - 423.47 kB - 08/24/2017 at 23:46 |
Scorpion3_0_comp_list.xlsxUpdated component list and estimate prices for building the entire devicesheet - 13.85 kB - 08/18/2017 at 00:55 |
20170816_234151.jpgfunctionality of the PCB-LCD assembly. Check the video from the logs for a more accurate description.JPEG Image - 1.53 MB - 08/17/2017 at 00:20 |
20170816_234008.jpgInner look of the actual PCB and LCD assemblyJPEG Image - 1.65 MB - 08/17/2017 at 00:18 |
non linear PWM pot.pngPWM potentiometer graph. Check the discussion sheet for detailsPortable Network Graphics (PNG) - 16.30 kB - 08/09/2017 at 06:20 |
PWM pot.pngPWM non linear potentiometer inserted into the LM2596 voltage divider feedback loop. Check the discussion sheet for more detailsPortable Network Graphics (PNG) - 36.91 kB - 08/09/2017 at 06:19 |
How to connect.pngDescriptive sheet on how to connect and what menu to select in order to achieve the desired function. More details in in the Instructions area.Portable Network Graphics (PNG) - 130.02 kB - 08/08/2017 at 04:43 |
Scorpion3_0_B2_layout.dipLayout of the B2 hardware variant. More details in the afferent log.dip - 421.40 kB - 08/07/2017 at 00:50 |
Scorpion3_0_B1.dchDip trace schematic file for the B1 iteration. Read the project logs for more informationdch - 297.51 kB - 08/04/2017 at 03:55 |
Scorpion_3_0_B1.xpsSchematic design for the B1 iteration. Read the project logs for more informationms-xpsdocument - 110.22 kB - 08/04/2017 at 03:53 |
Scorpion_3_0_firmware_A3.txtA3 firmware iteration for the Scorpion 3.0 project. you can find multiple details with the respective log.plain - 38.05 kB - 08/02/2017 at 03:32 |
custom char set table.pngI wanted to display some special chars on the LCD. These include:- a scorpion used for the logo - a rotate left arrow - a rotate right arrow - a push down arrow I also added the necessary bits needed to be transferred to my 4 pin connected display according to the connections from the schematic and the MCU pin assigment. Portable Network Graphics (PNG) - 23.94 kB - 07/31/2017 at 01:40 |
Scorpion_3_0_A2.xpsSchematic iteration A2 of the Scorpion 3.0 design. Temporary component values and labels.ms-xpsdocument - 98.24 kB - 07/28/2017 at 01:42 |
