Entries for the "Flashing Light Prize 2017"
"Flashing Light Prize 2017" is an informal & fun contest to make a light bulb flashing in the most craziest ways
The Flashing Light Prize is an informal & fun contest to find the most unusual way of flashing an incandescent light bulb. Build a system in line with the criteria set out below and you could win £200 ! Your creation could be something ridiculous and zany using bits of string and magnets or it could be a brilliantly elegant circuit topology that's never been tried before. It could be electronic, electromechanical, electrochemical, anything legal. All it's got to do is flash an incandescent bulb at between 0.5Hz and 2Hz. You even get to choose what kind of incandescent bulb to use.
Entry criteria:
You can use any size and voltage of incandescent bulb.
The flash rate must be between 0.5Hz and 2Hz. The mark-space ratio is unimportant but the difference between the bulb being on and off must be clearly visible.
The flashing must be done electrically (i.e. causing the filament in the bulb to glow on and off). A bulb that is on continuously but has shutters, lenses etc. moving in front of it is not an eligible entry.
Your system doesn't have to have amazing longevity but it must be able to run for at least 5 minutes without breaking down, exploding etc.
How to enter:
Build your unusual system for flashing a light bulb and make a video of it in action (complete with the bulb flashing, the system that's making it flash and a detailed description of how it works). Upload your video to YouTube and include "Flashing Light Prize 2017" in the title. Then tweet us @FlashingSystems to let us know !
The contest is open until the 1st of August 2017 whereupon the judges will review all the YouTube clips and decide the winner.
Contest page: https://www.flashinglightprize.com/
Entries from other applicants: https://www.flashinglightprize.com/entries
  • Frequency Shifter - "Flashing Light Prize 2017"
    RoGeorge • 08/01/2017 at 01:35 • 2 comments
    This video is the one that was supposed to be the interesting one, but sent mostly as raw footage:
    The project is made of 2 identical motors, each with 4 magnets on top, and a reed switch nearby. The 2 magnetic reed switches are in series with a light bulb and a battery. The motors rotate the magnets they have on top of their axle producing a rotating magnetic field.
    When the motors are at the right distance from the switches, the reed contacts start to vibrate in the rhythm of the rotating magnetic field. Motors rotate very fast, probably around 2000 RPM.
    The trick is that each motor has a slightly different RPM. The reed switches are in series, so they emulate a logic AND for the bulb. Boolean AND is the same as multiplication. Multiplying RPM1 and RPM2 corresponding frequencies will produce two spectral components with the frequency RPM1 + RPM2 and RPM1 - RPM2, because cos(x)cos(y)=1/2[cos(x−y)+cos(x+y)]
    As a result, the bulb filament will see two frequencies, RPM1 + RPM2, and another frequency RPM1 - RPM2. Because the filament has thermal inertia, it will act as a low pass filter, and it will attenuate the component of frequency RPM1 + RPM2.
    On the contrary, RPM1 - RPM2 will be in the range of about 1 Hz, and the light bulb will flash in the rhythm of RPM1 - RPM2.
    In the end, we managed to produce a 1 Hz oscillation started from 2 motors at about 2000 RPM.
    Same technique as used in telecommunication for frequency shifting, frequency modulation, software define radios, etc., but applied to an incandescent light bulb with the help of 2 reed switches.
  • Crazy light bulb flashing by itself
    RoGeorge • 08/01/2017 at 01:05 • 0 comments
    This video was made mainly to learn how to make and edit a video with Blender.
    Also, it was quite a surprise to find such a rare type of light bulb in one of my own junk boxes. I didn't knew such a thing even exists, never mind that I was having one.
  • Phew, what a day!
    RoGeorge • 08/01/2017 at 00:56 • 0 comments
    F*ck me!
    Just learned today Blender and Gimp, bad enough to make my first (edited) video. Assembled the project, made the shooting setup and filmed the raw footage. Also, made an account and figure out how to twitter (still not sure if I actually sent the tweet :o), in order to submit the videos to the "Flashing Light Prize 2017" contest. The last tweet was literally sent in the last minute. YouTube was nice enough and finished the second upload 2 minutes before the contest deadline, so it left me a full minute to send the tweet.
    Making videos is tedious!
    First one was made mainly to learn video editing, but I wasn't paying attention to the clock, and after I finished it, I realized there is no time for the second video, which was supposed to be the interesting one, so I made a kind of draft and published it anyway.
    Phew, what a day!
    :o)
View all 3 project logs
