Tower coating and making some hardware
A project log for Concrete CNC
This is an attempt at a cheap but rigid CNC machine (budget approx. 2000€)
david-risbergDavid Risberg 09/09/2017 at 15:200 Comments
The tower was coated with epoxy as soon as it had cooled down. It was coated inside a fume cupboard. While modern epoxy is not very toxic, proper ventilation is still fantastic.
Besides sealing the concrete, it gives a nice glossy finish to the part.
Next up is some mounting hardware for the Z-axis ballscrew.
The one for the floating side is simple, but the one for the fixed side is stiffened and machined on both sides, since it will also hold the stepper motor.
Next up is a sanity check regarding the fit. I want to make sure that the steel inserts in the tower matches the mounts and the ballscrew. This is especially important since I'm not drawing anything in CAD, but only building it on the fly.
Looks good!
Next up is machining the steel inserts for precision, and drilling and tapping some holes for the ball screw mounts.
