Configuration.hRepetier firmware configuration.h file. THis is setup to work without the annoying LCD and instead uses a raspberry pi (octoprint / octopi) as the controling server over wifi.h - 31.52 kB - 09/06/2017 at 16:12 |
Pin numbers.txtPin numbers for the Melzi control board found on this prusa i3 clone. A Melzi board is the same as a "Sanguino" - select this option when compiling under the arduino IDEplain - 1.12 kB - 09/06/2017 at 16:10 |
Motor-block.STLSupport for the stepper motor, to allow it to hang off the machine frameStandard Tesselated Geometry - 45.20 kB - 09/03/2017 at 21:21 |
Dual-hot-end-assembly.STEPComplete assembly of the geometrystep - 5.80 MB - 09/03/2017 at 21:09 |
Upgrade-block.STLLower half of the housing for the dual V6 headsStandard Tesselated Geometry - 5.59 MB - 09/03/2017 at 21:07 |
cooling_manifold_a2.STLTop half of the housing for the dual V6 headsStandard Tesselated Geometry - 4.62 MB - 09/03/2017 at 21:07 |
lower-manifold_a2.STLManifold for extruded material cooling fanStandard Tesselated Geometry - 4.51 MB - 09/03/2017 at 21:07 |
Slide-fixed.STLV6 mountStandard Tesselated Geometry - 39.14 kB - 09/03/2017 at 21:07 |
Slide-adjust.STLV6 adjustable mountStandard Tesselated Geometry - 39.14 kB - 09/03/2017 at 21:07 |
GT2-clamp.STLClamp for the GT2 cableStandard Tesselated Geometry - 51.06 kB - 09/03/2017 at 21:07 |
dummy-extruder.STLdummy extruder tube when using a single extruderStandard Tesselated Geometry - 28.21 kB - 09/03/2017 at 21:07 |
