Soap Bubble Machine
Automated Soap Bubble Machine controlled by Arduino with lasercut frame
Easy Arduino fun project and it makes bubbles!
This is a simple project to start with Arduino. A servo, a motor, some code and a lot of fun, especially for kids. The wooden frame is only a skeleton to keep the parts in place and therefore not suitable for kids hands.
It is possible to combine the machine with sensors and play with Arduino. I've tried an IR-remote and plan to use a PIR motion sensor in future.
Here is a PCB Adapter for an Arduino Pro Mini: https://oshpark.com/shared_projects/cWhLUbva
SoapBubbleMachine_L9110.ino
ino - 1.76 kB - 10/21/2017 at 11:31
Download
3mm SBM.dxf
AutoCAD DXF - 103.80 kB - 09/16/2017 at 10:41
Download
  • 1 × L9110 Fan Module
  • 1 × 9gr Servo
  • 1 × Arduino Pro Mini
  • 1 × Battery holder 4 AA
  • 1 × Toggle switch
  • Video
    Kenora03/13/2018 at 11:14 0 comments
  • New PCB arrived
    Kenora10/21/2017 at 11:40 0 comments
    New PCB arrived and tested. The fan speed can now be controlled by turning the potentiometer. For the battery I used a JST plug to get reverse polarity protection.
  • New PCB
    Kenora09/17/2017 at 09:42 0 comments
    I've added a potentiometer to the PCB to control the fan speed. The V1.0 board used a PWM pin, that does not support PWM. It is still possible to use one of the ISP pins (D11) which is directly beside the motor conector to use PWM control.
  • Video of one cycle
    Kenora09/16/2017 at 09:47 0 comments
View all 4 project logs
giloh64724 wrote 12/12/2022 at 13:57 point
This recreation ticks such a lot of packing containers. Made with sustainable substances, top notch customizable sport of countryball plushpieces/board/movements and techniques
Robyn wrote 11/07/2017 at 10:12 point
What did you use to make the red plastic ring? Did you 3d print it? Is so do you have the file.
