Chapter 1 - Pickle Rick Totem
A project log for Adaptator X and the chamber of Pickle-Rick
Our project is to create a structure allowing to fix any type of cellphone on a microscope to observe samples with precision.
benoitvanderzyppebenoit.vanderzyppe 09/15/2017 at 13:540 Comments
We first printed the 3D Pickle Rick.
The template was downloaded from thingiverse (https://www.thingiverse.com/thing:2452401).
The model was printed with 2 fluids : a classic one (white plastic) and a solvable one, which was used as support when creating the figurine.
The model was printed lying down to use less material.
Once printed, the Pickle rick was put in hot water for around an hour to remove the support.
It was painted with classic paint one day later
