We first printed the 3D Pickle Rick.
The template was downloaded from thingiverse (https://www.thingiverse.com/thing:2452401).
The model was printed with 2 fluids : a classic one (white plastic) and a solvable one, which was used as support when creating the figurine.
The model was printed lying down to use less material.
Once printed, the Pickle rick was put in hot water for around an hour to remove the support.
It was painted with classic paint one day later
