tanqueDeAgua.jpgIt's a tank to use.JPEG Image - 2.24 MB - 09/18/2017 at 15:09 |
ElectroValvula.jpgIt's an electro valve to use.JPEG Image - 1.83 MB - 09/18/2017 at 15:09 |
sim800l.jpgIt's a module SIM800L.JPEG Image - 134.12 kB - 09/18/2017 at 15:09 |
dht11.jpgIt's a sensor DHT11.JPEG Image - 81.98 kB - 09/18/2017 at 15:09 |
LCD16x2-BL.jpgIt's a Display LCD16x2.JPEG Image - 11.05 kB - 09/18/2017 at 15:09 |
ds18b20.jpgIt's a DS18B20 to use without the protected cableJPEG Image - 26.58 kB - 09/18/2017 at 15:09 |
DS18B20_cable.jpgIt's a DS18B20 to use with the protected cableJPEG Image - 20.83 kB - 09/18/2017 at 15:09 |
sensorOpticoSilkscreen.pdfBoard of connection to the Optical Sensor to measure the level of the tank. Silkscreen.Adobe Portable Document Format - 3.21 kB - 09/18/2017 at 14:59 |
sensorOpticoSoldierMask.pdfBoard of connection to the Optical Sensor to measure the level of the tank. Top layer or Soldier Mask.Adobe Portable Document Format - 1.75 kB - 09/18/2017 at 14:59 |
ldrPlacaSoldierMask.pdfBoard of connection to the LDR. Soldier Mask or top layer.Adobe Portable Document Format - 1.38 kB - 09/18/2017 at 14:58 |
ldrPlacaSilkscreen.pdfBoard of connection to the LDR. Silkscreen.Adobe Portable Document Format - 2.24 kB - 09/18/2017 at 14:58 |
dht11PlacaSoldierMask.pdfBoard of connection to the DHT11. Soldier Mask or Top layer.Adobe Portable Document Format - 1.54 kB - 09/18/2017 at 14:56 |
dht11PlacaSilkscreen.pdfBoard of connection to the DHT11. Silkscreen.Adobe Portable Document Format - 2.27 kB - 09/18/2017 at 14:56 |
circuitoControlValvulaSilkscreen.pdfControl circuit to the electro valve. Silkscreen.Adobe Portable Document Format - 3.90 kB - 09/18/2017 at 14:55 |
circuitoControlValvulaLayer.pdfControl circuit to the electro valve. Top Layer.Adobe Portable Document Format - 2.36 kB - 09/18/2017 at 14:55 |
JPEG Image - 10.95 MB - 09/18/2017 at 14:50 |
Datasheet Sim800L.pdfIt's a datasheet of module SIM800L who connect the system with the web page and sending the sms text.Adobe Portable Document Format - 2.70 MB - 09/18/2017 at 14:48 |
User Manual Nucleo-F401RE.pdfsmall user manual of the 64 core board.Adobe Portable Document Format - 3.37 MB - 09/18/2017 at 14:48 |
JPEG Image - 3.07 MB - 09/18/2017 at 14:47 |
Adobe Portable Document Format - 298.85 kB - 09/18/2017 at 14:46 |
Datasheet DS18B20.pdfThis is the datasheet of the sensor DS18B20 to measure the soil temperature. This works with the 1wire comunication.Adobe Portable Document Format - 484.15 kB - 09/18/2017 at 14:46 |
Datasheet DHT11.pdfThis is the datasheet of the sensor DHT11 to measure the ambient temperature and the humidity ambient relative.Adobe Portable Document Format - 842.29 kB - 09/18/2017 at 14:45 |
Datasheet Soil Moisture Sensor.pdfThis is the datasheet of the Higrometer to measure the soil humidity. It's an analogic sensor.Adobe Portable Document Format - 631.24 kB - 09/18/2017 at 14:45 |
STM32 Nucleo 64 Board.pdfA little bit document to explain the Nucleo Board 64 used.Adobe Portable Document Format - 257.14 kB - 09/18/2017 at 14:45 |
Conexion LCD.jpgLCD Connection to a microcontroller.JPEG Image - 179.19 kB - 09/18/2017 at 14:44 |
Conexion Bus 1Wire.jpgIt's a connection to bus 1wire.JPEG Image - 22.22 kB - 09/18/2017 at 14:44 |
Codigo de Resistencias.jpgResistance Code.JPEG Image - 43.38 kB - 09/18/2017 at 14:44 |
Adobe Portable Document Format - 148.89 kB - 09/18/2017 at 14:44 |
Conexion DHT11.jpgConnection to DHT11JPEG Image - 8.33 kB - 09/18/2017 at 14:44 |
