Transformer
A project log for Nixie Tap
Minimal USB powered Nixie display and IoT button
mladenmladen 11/13/2019 at 22:253 Comments
Transformer is custom made, hand wound.
To start, you'll need:
  1. Ferrites: 2pcs of TDK B66305G0040X127 (E13/7/4 core halves, material N27, 0.04 mm gap)
  2. Coil Former: B66306C1010T001
  3. Primary: 0.3mm diameter enamel wire
  4. Secondary: 0.1mm diameter enamel wire
Instructions (warning: CRAPPY PICTURE QUALITY :( )
You're done with the primary winding. Now onto the secondary.
Again, sorry for  the eye-cancer-inducing photos, these will have to do the job. For any questions, please write!
Vlad Conut wrote 11/19/2019 at 08:39 point
oh sweet, gonna make myself some transformers now :D
if time permits maybe you can go a bit into details on how you come up with the number of turns for primary/secondary, how was the wire diameter calculated and so on.
Akhan Almagamb├ętov wrote 11/19/2019 at 01:23 point
I really appreciate you posting this tutorial!  Thank you so much!
Aleksey wrote 11/14/2019 at 18:43 point
Hi. Thanks for sharing your experience. It was very interesting for me. Thanks again.
