External Monitor
A project log for The PCW Project
Doing things with an Amstrad PCW
james-otsJames Ots 10/04/2017 at 22:330 Comments
I found a circuit diagram online for connecting a PCW to an external monitor. So I made it, connected it to a Video to VGA convert box, and then to an LCD monitor. It does display something vaguely recognisable, but it isn't very good. Whether it's because I built it badly, so it's picking up lots of interference, or because the converter box isn't very good, or because the circuit is wrong, or because the monitor doesn't like the resolution, I don't know. I'm sure I can get there eventually. (I'm kind of tempted to use my FPGA board to convert the signal to HDMI…)
PCW display on an LCD monitorPCW to composite video converter
