Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
AutoFuse: Plug and Use Automation & power monitor
Plugs into the fuse socket of mediocre switch boards, connects it to WiFi and monitors the power consumption of that room through smartphone
Animesh ChattopadhyayAnimesh Chattopadhyay
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
426 followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
  • The 2017 Hackaday Prize
View Gallery
426
0
426
2
Team (1)
  • Animesh ChattopadhyayAnimesh Chattopadhyay
Join this project's team
hardware
ongoing project
2017HackadayPrize power monitor home automation iot arduino ESP8266
This project is submitted for
  • Anything Goes
This project was created on 10/15/2017 and last updated 2 years ago.
Description
A different approach to automating your home by exploiting the regular switchboards present in most of our home. Replaces the standard AC fuse placed on Electrical Switchboards. It monitors the Power consumption of all the appliances connected to that board. It can also power off the entire board in case there are no occupants in that room. It doesn't need to modify the board just pull out the normal fuse and plug this in its place and you have got your room automated, hence the name.
Power consumption can be monitored and the device can be configured through your smartphone. Planning of adding an OLED display in next versions of the hardware to display the real-time feed right on the board itself.
Components
  • 1 × ACS712 In series Current measurement module IC
  • 1 × Arduino(Bluetooth HC 05) or ESP8266(future)
  • 1 × 5v Relay For turning off all appliances
  • 1 × AC Fuse 13A In series for safety
  • 1 × 5v AC-DC power supply module
View all 7 components
Project Logs
Collapse logs
  • Got listed in IEEE Maker Project
    Animesh Chattopadhyay • 11/18/2017 at 07:27 • 0 comments
    IEEE Maker Project: AutoFuse
  • Checking the connection with smartphone
    Animesh Chattopadhyay • 10/16/2017 at 12:25 • 0 comments
    Using Blynk for the control and interface
  • Programming and testing the current sensor
    Animesh Chattopadhyay • 10/16/2017 at 12:22 • 0 comments
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
ATX power supply adapter board for classic IBM XT/AT computers
Project Owner Contributor
ATX2XT PSU Adapter
Dave's Dev LabDave's Dev Lab
A simple breakout board for an ATX power supply
ATX Power Supply Breakout Board
This project can be used to monitor the AC line that is connected to the CS5463 power analyzer breakout board.
Power Monitor
4D Makers4D Makers
I'm trying to resurrect a 1990's Greenspring VME SBC based on the MC68000, with OS/9 roms.
A 68000 based VME SBC with OS/9
JrsphotoJrsphoto
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "AutoFuse: Plug and Use Automation & power monitor", please tell us the reason.
Send message
Remove Member
