IMG_20171023_123442.jpgupdated LoRa client, showing current frequencyError() in the top right corner.RSSI and SNR in the top left corner. JPEG Image - 1.54 MB - 10/23/2017 at 12:18 |
gqrx.jpgWaterfall Display showing sender and receiver with exact matching frequencies.Modulation: 15.6kHz Bandwidth, 4/8 Coding Rate, Spreading Factor 512 on 433MHz ISM Band JPEG Image - 220.78 kB - 10/23/2017 at 11:12 |
IMG_20171018_161036.jpglora sender and receiver - receiver showing rssi and snrJPEG Image - 1.79 MB - 10/18/2017 at 14:16 |
LoRaOLED_sender.inoExample LoRa sender sketch. RF modem configured for long range transmission on 434.5MHzx-arduino - 2.63 kB - 10/18/2017 at 14:04 |
LoRaOLED_receiver.inoExample LoRa receiver sketch showing received packets, RSSI and SNR on integrated OLEDx-arduino - 3.08 kB - 10/18/2017 at 14:03 |
