IMG_20171011_190028.jpgView of the BIOSJPEG Image - 5.11 MB - 10/25/2017 at 15:22 |
IMG_20171024_225518.jpgFinished case rear viewJPEG Image - 4.78 MB - 10/25/2017 at 15:22 |
IMG_20171024_225550.jpgFinished case front left viewJPEG Image - 4.42 MB - 10/25/2017 at 15:22 |
IMG_20171024_232236.jpgCluster running rear viewJPEG Image - 4.25 MB - 10/25/2017 at 15:22 |
IMG_20171024_142838.jpgTable of parts ready to build!JPEG Image - 4.51 MB - 10/25/2017 at 15:22 |
IMG_20171011_180959.jpgSSD mounting hardwareJPEG Image - 4.25 MB - 10/25/2017 at 15:22 |
IMG_20171024_225530.jpgFinished case front right viewJPEG Image - 4.31 MB - 10/25/2017 at 15:22 |
IMG_20171024_211101.jpgSwitches being installed inside viewJPEG Image - 4.02 MB - 10/25/2017 at 15:22 |
IMG_20171024_215836.jpgTest fitting PSU and cable lengthsJPEG Image - 4.02 MB - 10/25/2017 at 15:21 |
IMG_20171012_232455.jpgCAD case design using OnshapeJPEG Image - 4.19 MB - 10/25/2017 at 15:21 |
IMG_20171024_232211.jpgCluster next to small computerJPEG Image - 3.88 MB - 10/25/2017 at 15:21 |
IMG_20171024_232223.jpgCluster running front viewJPEG Image - 3.95 MB - 10/25/2017 at 15:21 |
IMG_20171011_145058.jpgRouter and switch bare boardsJPEG Image - 3.78 MB - 10/25/2017 at 15:21 |
IMG_20171024_211047.jpgSwitches being install outside viewJPEG Image - 3.87 MB - 10/25/2017 at 15:21 |
IMG_20171024_223857.jpgConnecting and routing cablesJPEG Image - 3.93 MB - 10/25/2017 at 15:21 |
IMG_20171024_223846.jpgEthernet cables connectedJPEG Image - 3.82 MB - 10/25/2017 at 15:21 |
IMG_20171024_161921.jpgSwitch cables all solderedJPEG Image - 3.86 MB - 10/25/2017 at 15:21 |
IMG_20171024_224921.jpgCase assembled top viewJPEG Image - 3.80 MB - 10/25/2017 at 15:21 |
IMG_20171010_163735.jpgFirst parts to arrive (switch, router, PSU)JPEG Image - 3.85 MB - 10/25/2017 at 15:21 |
IMG_20171024_224913.jpgCase assembled rear viewJPEG Image - 3.76 MB - 10/25/2017 at 15:21 |
IMG_20171011_182714.jpgDouble sided tape for CMOS batteryJPEG Image - 3.66 MB - 10/25/2017 at 15:21 |
IMG_20171024_222128.jpgConnected wire harnesses to PSUJPEG Image - 3.77 MB - 10/25/2017 at 15:21 |
IMG_20171011_145013.jpgBare router board and switch still in caseJPEG Image - 3.66 MB - 10/25/2017 at 15:21 |
IMG_20171024_164758.jpgCase first panels joinedJPEG Image - 3.61 MB - 10/25/2017 at 15:21 |
IMG_20171024_163146.jpgSwitch mounted on panelJPEG Image - 3.54 MB - 10/25/2017 at 15:21 |
IMG_20171023_183552.jpgFirst wire harness finishedJPEG Image - 3.50 MB - 10/25/2017 at 15:21 |
IMG_20171024_163850.jpgTesting board cooling alignmentJPEG Image - 3.37 MB - 10/25/2017 at 15:21 |
IMG_20171023_183057.jpgFinished soldering first wiring harnessJPEG Image - 3.25 MB - 10/25/2017 at 15:21 |
IMG_20171023_182342.jpgStarting soldering first wiring harnessJPEG Image - 3.35 MB - 10/25/2017 at 15:21 |
IMG_20171011_181252.jpgBoard with CMOS battery and SSD mountedJPEG Image - 3.25 MB - 10/25/2017 at 15:21 |
IMG_20171024_232300.jpgCluster running top viewJPEG Image - 3.23 MB - 10/25/2017 at 15:21 |
IMG_20171024_163856.jpgTesting board cooling alignment (bad alignment)JPEG Image - 3.28 MB - 10/25/2017 at 15:21 |
IMG_20171011_182746.jpgCMOS battery taped to boardJPEG Image - 2.94 MB - 10/25/2017 at 15:21 |
IMG_20171024_145449.jpgRouter mounted to baseJPEG Image - 3.03 MB - 10/25/2017 at 15:21 |
IMG_20171024_130323.jpgTesting first t slot jointJPEG Image - 2.74 MB - 10/25/2017 at 15:21 |
IMG_20171024_145050.jpgPeeling the protective acrylic film awayJPEG Image - 2.68 MB - 10/25/2017 at 15:21 |
IMG_20171024_144707.jpgChecking clearance between router and UDOOJPEG Image - 2.93 MB - 10/25/2017 at 15:21 |
IMG_20171024_160728.jpgSoldering up switch wiresJPEG Image - 2.72 MB - 10/25/2017 at 15:21 |
IMG_20171024_145436.jpgRouter mounting bottom panel screwsJPEG Image - 2.66 MB - 10/25/2017 at 15:21 |
IMG_20171024_152010.jpgChecking PSU t slot clearance (eek)JPEG Image - 2.61 MB - 10/25/2017 at 15:21 |
