Particle Core LED Matrix
Hook up 16 8x8 LED Matrices with a Particle Core (formerly Spark)
Custom PCB for an 8x8 LED Matrix circuit with through-hole components, hooked up "motherboard" on which a Particle Core is plugged - Together with a simplistic custom website that can be used to send messages to display on the 16 LED matrices as an LED screen.
  • 16 × NFM-12883 8x8 LED Matrix
  • 1 × Particle Core At the time it was called Spark Core :)
  • 16 × AS-1100PL Interface and IO ICs / Display Interface
  • 12 × OpenBean aluminium profiles Create the box structure on which transparent black acrylic is bolted
