Фото0719.jpgBEFORE TESTS...and then the ternary logic for the synchronization generator of the decoder's heart ... JPEG Image - 156.66 kB - 12/20/2017 at 13:13 |
Фото0717.jpgSo, day by day, vacation is already coming to an endJPEG Image - 308.32 kB - 12/20/2017 at 13:12 |
Фото0716.jpgAssembling the DecoderJPEG Image - 356.95 kB - 12/20/2017 at 13:12 |
Фото0715.jpgTrinity KeysJPEG Image - 273.91 kB - 12/20/2017 at 13:12 |
Фото0714.jpgExternal decoder panel, work with a jigsawJPEG Image - 305.00 kB - 12/20/2017 at 13:12 |
Фото0713.jpgKeyboard design, a lot of mechanical workJPEG Image - 233.46 kB - 12/20/2017 at 13:11 |
Фото0712.jpgStage preparation of keyboard keysJPEG Image - 220.14 kB - 12/20/2017 at 13:11 |
Фото0711.jpgneed a ternary keyboardJPEG Image - 284.95 kB - 12/20/2017 at 13:10 |
Фото0710.jpgBinary Reed Exchange Keyboard ModuleJPEG Image - 340.63 kB - 12/20/2017 at 13:10 |
Фото0709.jpgOnce in the ternary system.JPEG Image - 291.38 kB - 12/20/2017 at 13:09 |
Фото0708.jpga modernized block of memory ... Sometimes it happens.JPEG Image - 369.55 kB - 12/20/2017 at 13:09 |
Фото0706.jpgThe continuation of the project - there are new ideasJPEG Image - 260.48 kB - 12/20/2017 at 13:07 |
Фото0705.jpgThe block of indication of a triple-decoded decoder into four lines of a physical channelJPEG Image - 326.19 kB - 12/20/2017 at 13:07 |
Фото0704.jpgDevelopment of the ternary keyboardJPEG Image - 326.90 kB - 12/20/2017 at 13:06 |
Фото0703.jpgBlock of static memory for 4 tritas and muliplexer of ternary levelsJPEG Image - 307.58 kB - 12/20/2017 at 13:06 |
Фото0702.jpgNext stage of the project installation of the decoding unitJPEG Image - 288.99 kB - 12/20/2017 at 13:06 |
Фото0701.jpgPower supply of non-symmetrical ternary systemlevel of logic 0 = +5 Volts logical level 1 = -5 Volts level of logic 2 = -2.5 Volts maximum amperage of 1.5 amps JPEG Image - 296.61 kB - 12/20/2017 at 13:04 |
