x10 tm4c123gxl
A project log for RH_RF95
added the registers and a couple of functions so that FSK/OOK can be used on the Feather 32u4 w/ 433MHz LoRa radio
jlbrian7jlbrian7 12/24/2017 at 11:440 Comments
Since I now have a cheap 433MHz transmitter, which I took out of the remote, I hooked it up to my tm4c123gxl in order to test my code.
// blinky.c - Simple example to blink the on-board LED.
// Copyright (c) 2012-2016 Texas Instruments Incorporated.  All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.3.156 of the EK-TM4C123GXL Firmware Package.
#include <stdint.h>
#include <stdbool.h>
#include <stdlib.h>
#include "inc/hw_memmap.h"
#include "driverlib/gpio.h"
#include "driverlib/sysctl.h"
#include "driverlib/rom.h"
#define ON     0x00
#define OFF    0x20
#define BRIGHT 0x88
#define DIM    0x98
#define X10_RF_SB_LONG          8960     // Start burts (leader) = 9ms
#define X10_RF_SB_SHORT         4500     // Start silecence (leader) = 4,5 ms
#define X10_RF_BIT_LONG         1120     // Bit 1 pulse length
#define X10_RF_BIT_SHORT        560      // Bit 1 pulse length
#define X10_RF_GAP              40000    // Length between commands
#define bitRead(value, bit) (((value) >> (bit)) & 0x01)
#define bitSet(value, bit) ((value) |= (1UL << (bit)))
#define bitClear(value, bit) ((value) &= ~(1UL << (bit)))
#define bitWrite(value, bit, bitvalue) (bitvalue ? bitSet(value, bit) : bitClear(value, bit))
void x10Switch(char house_code, uint8_t unit_code, uint8_t command);
void SendCommand(uint8_t *data, uint8_t size);
void SendX10RfByte(uint8_t data);
void SendX10RfBit(unsigned int databit);
void SEND_HIGH();
void SEND_LOW();
uint8_t _rf_repeats = 5;
void delayUS(uint32_t us) {
    ROM_SysCtlDelay( (ROM_SysCtlClockGet()/(3*1000*1000))*us ) ;  // more accurate
int
main(void)
    volatile uint32_t ui32Loop;
    //80Mhz
    //ROM_SysCtlClockSet(SYSCTL_SYSDIV_2_5 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ);
    // Enable the GPIO port that is used for the on-board LED.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
    // port used for the transmitter
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
    // Check if the peripheral access is enabled.
    while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOF))
    // Enable the GPIO pin for the LED (PF3).  Set the direction as output, and
    // enable the GPIO pin for digital function.
    GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_3);
    //enable
    GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_0);
    GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_0, GPIO_PIN_0);
    //signal
    GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_5);
    // Loop forever.
    while(1)
        // Turn on the LED.
        GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, GPIO_PIN_3);
        // Delay for a bit.
        for(ui32Loop = 0; ui32Loop < 200000; ui32Loop++)
        // Turn off the LED.
        GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, 0x0);
        // Delay for a bit.
        x10Switch('A', 2, ON); // Switch A1 On
        delayUS(3000000);
        delayUS(3000000);
void x10Switch(char house_code, uint8_t unit_code, uint8_t command){
    uint8_t x10buff[4]; // Set message buffer 4 bytes
    switch(house_code) {
        case 'A': x10buff[0] = 0b0110; break;
        case 'B': x10buff[0] = 0b0111; break;
        case 'C': x10buff[0] = 0b0100; break;
        case 'D': x10buff[0] = 0b0101; break;
        case 'E': x10buff[0] = 0b1000; break;
        case 'F': x10buff[0] = 0b1001; break;
        case 'G': x10buff[0] = 0b1010; break;
        case 'H': x10buff[0] = 0b1011; break;
        case 'I': x10buff[0] = 0b1110; break;
        case 'J': x10buff[0] = 0b1111; break;
        case 'K': x10buff[0] = 0b1100; break;
        case 'L': x10buff[0] = 0b1101; break;
        case 'M': x10buff[0] = 0b0000; break;
        case 'N': x10buff[0] = 0b0001; break;
        case 'O': x10buff[0] = 0b0010; break;
        case 'P': x10buff[0] = 0b0011; break;
        default:  x10buff[0] = 0;     break;
    x10buff[0] = x10buff[0] << 4; // House code goes into the upper nibble
    x10buff[2] = command;
    /*switch(command) {
      case ON:
      case OFF:
      case BRIGHT:
      case DIM:
    // Set unit number
    unit_code = unit_code - 1;
    bitWrite(x10buff[2],6,bitRead(unit_code,2));
    bitWrite(x10buff[2],3,bitRead(unit_code,1));
    bitWrite(x10buff[2],4,bitRead(unit_code,0));
    bitWrite(x10buff[0],2,bitRead(unit_code,3));
    // Set parity
    x10buff[1] = ~x10buff[0];
    x10buff[3] = ~x10buff[2];
    SendCommand(x10buff, sizeof(x10buff));
void SendCommand(uint8_t *data, uint8_t size){
    uint8_t i = 0;
    int j = 0;
    for(i = 0; i < _rf_repeats; i++){
        SEND_HIGH();
        delayUS(X10_RF_SB_LONG);
        SEND_LOW();
        delayUS(X10_RF_SB_SHORT);
        for(j=0; j <= size; j++) {
            SendX10RfByte(data[j]);
    SendX10RfBit(1);
    delayUS(X10_RF_GAP);
void SendX10RfByte(uint8_t data){
    int i = 0;
    //Serial.println("\n");
    for(i=7; i >= 0; i--){ // send bits from byte
        SendX10RfBit((bitRead(data,i)==1));
        //Serial.print(bitRead(data,i));
void SendX10RfBit(unsigned int databit){
    SEND_HIGH();
    delayUS(X10_RF_BIT_SHORT);
    SEND_LOW();
    if (databit){
        delayUS(X10_RF_BIT_LONG);
void SEND_HIGH() {
    GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_5, GPIO_PIN_5);
void SEND_LOW(){
    GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_5, 0x0);
This code, and the transmitter from the remote had the light flashing on and off just as expected.
So, back to figuring out what I am doing wrong with the radio.
