Since I now have a cheap 433MHz transmitter, which I took out of the remote, I hooked it up to my tm4c123gxl in order to test my code.
// blinky.c - Simple example to blink the on-board LED.
// Copyright (c) 2012-2016 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.3.156 of the EK-TM4C123GXL Firmware Package.
#include <stdint.h>
#include <stdbool.h>
#include <stdlib.h>
#include "inc/hw_memmap.h"
#include "driverlib/gpio.h"
#include "driverlib/sysctl.h"
#include "driverlib/rom.h"
#define ON 0x00
#define OFF 0x20
#define BRIGHT 0x88
#define DIM 0x98
#define X10_RF_SB_LONG 8960 // Start burts (leader) = 9ms
#define X10_RF_SB_SHORT 4500 // Start silecence (leader) = 4,5 ms
#define X10_RF_BIT_LONG 1120 // Bit 1 pulse length
#define X10_RF_BIT_SHORT 560 // Bit 1 pulse length
#define X10_RF_GAP 40000 // Length between commands
#define bitRead(value, bit) (((value) >> (bit)) & 0x01)
#define bitSet(value, bit) ((value) |= (1UL << (bit)))
#define bitClear(value, bit) ((value) &= ~(1UL << (bit)))
#define bitWrite(value, bit, bitvalue) (bitvalue ? bitSet(value, bit) : bitClear(value, bit))
void x10Switch(char house_code, uint8_t unit_code, uint8_t command);
void SendCommand(uint8_t *data, uint8_t size);
void SendX10RfByte(uint8_t data);
void SendX10RfBit(unsigned int databit);
void SEND_HIGH();
void SEND_LOW();
uint8_t _rf_repeats = 5;
void delayUS(uint32_t us) {
ROM_SysCtlDelay( (ROM_SysCtlClockGet()/(3*1000*1000))*us ) ; // more accurate
int
main(void)
volatile uint32_t ui32Loop;
//80Mhz
//ROM_SysCtlClockSet(SYSCTL_SYSDIV_2_5 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ);
// Enable the GPIO port that is used for the on-board LED.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
// port used for the transmitter
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
// Check if the peripheral access is enabled.
while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOF))
// Enable the GPIO pin for the LED (PF3). Set the direction as output, and
// enable the GPIO pin for digital function.
GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_3);
//enable
GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_0);
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_0, GPIO_PIN_0);
//signal
GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_5);
// Loop forever.
while(1)
// Turn on the LED.
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, GPIO_PIN_3);
// Delay for a bit.
for(ui32Loop = 0; ui32Loop < 200000; ui32Loop++)
// Turn off the LED.
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, 0x0);
// Delay for a bit.
x10Switch('A', 2, ON); // Switch A1 On
delayUS(3000000);
delayUS(3000000);
void x10Switch(char house_code, uint8_t unit_code, uint8_t command){
uint8_t x10buff[4]; // Set message buffer 4 bytes
switch(house_code) {
case 'A': x10buff[0] = 0b0110; break;
case 'B': x10buff[0] = 0b0111; break;
case 'C': x10buff[0] = 0b0100; break;
case 'D': x10buff[0] = 0b0101; break;
case 'E': x10buff[0] = 0b1000; break;
case 'F': x10buff[0] = 0b1001; break;
case 'G': x10buff[0] = 0b1010; break;
case 'H': x10buff[0] = 0b1011; break;
case 'I': x10buff[0] = 0b1110; break;
case 'J': x10buff[0] = 0b1111; break;
case 'K': x10buff[0] = 0b1100; break;
case 'L': x10buff[0] = 0b1101; break;
case 'M': x10buff[0] = 0b0000; break;
case 'N': x10buff[0] = 0b0001; break;
case 'O': x10buff[0] = 0b0010; break;
case 'P': x10buff[0] = 0b0011; break;
default: x10buff[0] = 0; break;
x10buff[0] = x10buff[0] << 4; // House code goes into the upper nibble
x10buff[2] = command;
/*switch(command) {
case ON:
case OFF:
case BRIGHT:
case DIM:
// Set unit number
unit_code = unit_code - 1;
bitWrite(x10buff[2],6,bitRead(unit_code,2));
bitWrite(x10buff[2],3,bitRead(unit_code,1));
bitWrite(x10buff[2],4,bitRead(unit_code,0));
bitWrite(x10buff[0],2,bitRead(unit_code,3));
// Set parity
x10buff[1] = ~x10buff[0];
x10buff[3] = ~x10buff[2];
SendCommand(x10buff, sizeof(x10buff));
void SendCommand(uint8_t *data, uint8_t size){
uint8_t i = 0;
int j = 0;
for(i = 0; i < _rf_repeats; i++){
SEND_HIGH();
delayUS(X10_RF_SB_LONG);
SEND_LOW();
delayUS(X10_RF_SB_SHORT);
for(j=0; j <= size; j++) {
SendX10RfByte(data[j]);
SendX10RfBit(1);
delayUS(X10_RF_GAP);
void SendX10RfByte(uint8_t data){
int i = 0;
//Serial.println("\n");
for(i=7; i >= 0; i--){ // send bits from byte
SendX10RfBit((bitRead(data,i)==1));
//Serial.print(bitRead(data,i));
void SendX10RfBit(unsigned int databit){
SEND_HIGH();
delayUS(X10_RF_BIT_SHORT);
SEND_LOW();
if (databit){
delayUS(X10_RF_BIT_LONG);
void SEND_HIGH() {
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_5, GPIO_PIN_5);
void SEND_LOW(){
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_5, 0x0);
This code, and the transmitter from the remote had the light flashing on and off just as expected.
So, back to figuring out what I am doing wrong with the radio.
