I ordered 10 pcbs from China and they are in . They turned out good and seem to be very high quality. They are 10 cm X 10 cm. I designed the PCB to take 2 kinds of power resistors and actually found the NI 10 Watt resistors for a good price so I used them. The circuit is a loose copy of the Amplifone with the WG6100's spot kill circuit. I used Tip35C and Tip36C transistors for the outputs and Tip31C and Tip32C's replaced some older transistors. I am still waiting for some more parts to arrive so that I can start to test these.
Im trying to run vector graphics on old crt tvs to play oscilloscope music and would be interested in acquiring or buying your custom pcbs, is this possible?
