And the boards crossed the Atlantic ocean and arrived in the mailbox! It’s always a pleasure to solder components on these high quality boards (even 0805 with a soldering iron).
To program the PIC, I forgot to order some 1.27mm spacing pin headers. However, there is a solution with two 2.54mm ones:
