A small design change.
A project log for Simple DIY laser cutter
Basic laser cutter than can be made with standard shop tools.
philphil 03/15/2014 at 12:050 Comments
I have decided to flip the X axis stepper on top on the X axis.  The reasons for this are I cut out needing 2 idler pulleys and the motor mount can be simplified meaning both motor mounts are the same!
Although I lose a little X axis cutting space it's not enough to worry about and should speed up the build process.  More pictures to follow soon!
