NAND Flash recovery??
This isn't so much a project as a cry for help. I am at a loss as to how I can save the data on this SD card. Well.. the pieces of my SD card anyway. I have some very precious photos that I really need to extract. The NAND flash chips are both intact, a few of the pins on one are slightly broken/bent though. The controller chip is ripped. I had the "bright" idea of desoldering the remaining chip and resoldering them onto a new controller chip. Of course that idea sounds way too simple so I'm assuming it wont work. What methods can I use to extract the data from these chips??
suomi2022 wrote 02/15/2022 at 20:01 point
I can do it,
