In this project I will be making homemade F class rocket motors using supplies you could get from walmart. Warning you can really hurt yourself playing with fire and rocket fuel and I will not take any responsibility for any injury or death caused by these rockets. Also do us all a favor and don't do anything stupid with these rockets.
Components
1×
Spectracide stump remover
This is an easy source of potassium nitrate
You must begin buy taking a mixture of 65% stump remover and 35% sugar. If you chose to add aluminum or baking powder you would add 60% stump killer, 5% aluminum or baking powder, and 35% sugar.
2
Step 2
Next you will mix the mixture with a little water and put it in an old frying pan that you don't want anymore.
3
Step 3
With your stove on low gradually heat this mixture for 30 minutes.
And this is exactly how you end up on one of those "lists" that get you probed every time you fly.
