extruder-main.scadMain file for Prusa i3 mk2 extruder. Modified to accomodate M4 screws for mounting, moved the stepper a little for E3D Hobb-Goblin, added two tiny printed gears to make it dual-drive-gear. Modify as needed.scad - 14.21 kB - 03/18/2018 at 12:19 |
gear_library.scadLibrary for gears. Really great!scad - 26.89 kB - 03/18/2018 at 12:19 |
gear.scadMain file for Prusa i3 mk2 extruder. Modified to accomodate M4 screws for mounting, moved the stepper a little for E3D Hobb-Goblin, added two tiny printed gears to make it dual-drive-gear. Modify as needed.scad - 312.00 bytes - 03/18/2018 at 12:19 |
extruder-body.scadMain file for Prusa i3 mk2 extruder. Modified to accomodate M4 screws for mounting, moved the stepper a little for E3D Hobb-Goblin, added two tiny printed gears to make it dual-drive-gear. Modify as needed.scad - 170.00 bytes - 03/18/2018 at 12:19 |
extruder-idler.scadMain file for Prusa i3 mk2 extruder. Modified to accomodate M4 screws for mounting, moved the stepper a little for E3D Hobb-Goblin, added two tiny printed gears to make it dual-drive-gear. Modify as needed.scad - 5.49 kB - 03/18/2018 at 12:19 |
door_clip.scadPatio hinge / lock / clip file.scad - 2.56 kB - 01/17/2018 at 08:29 |
