Hackaday.io Hackaday.io
Sign up Log in
PIXO Pixel
EPS32 Based RGB Display that uses the APA102-2020 LED
sean-hodginsSean Hodgins
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.3k views
0 comments
56 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
4.3k
0
56
42
Team (1)
  • sean-hodginsSean Hodgins
Join this project's team
  • KICKSTARTER!
  • GitHub
  • FIndChips(BOM)
hardware
ongoing project
ESP32 arduino APA102 led lights matrix iot wifi ble
This project was created on 01/18/2018 and last updated 7 years ago.
Description
I wanted to create a simple to program LED matrix that runs off of the ESP32 so that it would have Bluetooth and WiFi connectivity. I didn't want it to be overly large like some of the displays already available, and I wanted to have a 16 x 16 grid pattern so that basic "8-bit" style images could be recreated. I decided to go with the incredibly small, fast, and awesome, APA102-2020. They are a 2mm x 2mm addressable LEDs. This will be a part of the Kickstarter Make/100 project which will be launching January 31st.
Project Logs
Collapse
  • Make/100 Kickstarter is Complete!
    Sean Hodgins • 06/21/2018 at 13:03 • 0 comments
    PIXO Pixels are complete and shipped!
  • Pictures, Pong, and Particle Physics
    Sean Hodgins • 02/14/2018 at 13:53 • 0 comments
    Here is a run down on how to display a few things on the PIXO Pixel. I have made a python script to convert images into a C++ 8-bit array to put them in your code, show you how to make a quick game of pong, and finally, experiment with some particle physics!
  • Building a PIXO Pixel
    Sean Hodgins • 02/13/2018 at 01:57 • 0 comments
    Want to build your own #PIXOPixel? The LEDs are the most fun.
  • Kickstarter is LIVE!
    Sean Hodgins • 01/30/2018 at 15:00 • 0 comments
    Only building 100, after that you will have to build your own!
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
The 2017 Hackaday Prize
Not just any Led matrix you've seen... You can play Retro Games like Pong from anywhere in the world with your phone.
Project Owner Contributor
Web Enabled Led Matrix
cabattistacaBattista
2021 Hackaday Prize
A multifunctional home display and optical notification system for everyone
pxlBlck - An unobtrusive home information display
fabianFabian
40-DPI monochrome LED module designed for persistence-of-vision displays. 16-element bargraph in an 8-pin castellated DIP package.
Rotovis-Mod1
zakqwyzakqwy
Ambient LED artwork created by playing an animated GIF in extreme slow motion with high LED refresh rate, and interpolation between frames.
Continuum - Slow Motion LED Art Display
louis-beaudoinLouis Beaudoin
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "PIXO Pixel", please tell us the reason.
Send message
Remove Member
