The major problem now in using ESP8266 for WiFi router routed application, is the IP address that is got to be written in the program ( say for Arduino) so it cannot be changed by a lame user.We have successfully overcome this by writing the vales of SSID & Password every time it faces a new wifi router on a serial terminal like (most user friendly is from Hackaday.--http://hackaday.io/project/3568-esp8266-test-program) .Run all the AT commands till you complete the SSID & Password and then remove the ESP and use it with any Arduino interface with program running from thereafter..
ucpatnaik
Lukas Vozenilek
CFA
JoaoLopesF
am interested in seeing how you go about the Android phone part of it.
