Millions in under-dev countries walk miles to get water. Take a normal bike, add a cheap electric motor run via solar panel for water transp
Perhaps, that electric motor can also double-up as a water pump motor. In case, one needs to use a hand pump manually, the same cheap electric motor can help.
jfolks
Marcel
Anteneh Gashaw
nodemcu12ecanada
Yes, delete it Cancel
You are about to report the project "Water Carrier", please tell us the reason.
