Created a voltage/current module
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary 03/27/2014 at 00:250 Comments
Took the messy wires and create a module that makes interface a little easier. In the next module I will skip  the voltage divider module and just use a couple of resistors for a cleaner look.
FRONT VIEW.
REAR VIEW.
