Current and voltage modules
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary 03/24/2014 at 00:460 Comments
This jumble of wires has both the current and voltage modules wired up. I need a better sub-module to hold both of these modules. That will be the next task.
