Pipe routing decision made
A project log for Budget BarBot
A BarBot for dispensing cocktails (on a budget)
david-hopkinsDavid Hopkins 02/02/2015 at 10:560 Comments
its going to be a through-board solution, it will be a little more tricky to make as will need to design all the holes before drilling, and slightly more fiddly to assemble, but it will look a lot nicer, a neater look. Also allows for some kind of edging on the baseboard
