Install AC
A project log for Big Old Bus RV Conversion
Living in a 1962 Wayne Bus while converting it!
conradConrad 02/13/2015 at 18:090 Comments
Bought a new window unit to cool the oven/bus had to remove entire window to install. I also added a 2x2 across the top of the ac for support as there is no window to pull down and seal it. I used parts of the window i took out to make the upper window. Looks ok for now but could use some fine tuning later. I have to get this thing going its getting hot in there!
