Quick Heater Mod.
A project log for Big Old Bus RV Conversion
Living in a 1962 Wayne Bus while converting it!
conradConrad 03/02/2015 at 19:180 Comments
I have been useing a propane heater that uses the green Coleman canisters with an adapter that lets me hookup a 5 gallon tank with a hose instead of the little tanks into the base of the heater. The problem with this is the heater is designed to sit on the Coleman tank that I replaced with a hose and is now unable to stand on its own plus the heater turns off when unlevel. I have been kinda hanging it up and propping it on top of various things most unsafely,very very frustrating when your cold! So I decided to take an old telescope tripod and attache the heater to the top for a base. Here's the result!
