Reverse engineering the Checksum
A project log for re-purposing acurite temperature sensors
Two people have reverse engineered most of the protocol. These things are cheap, and do something I wanted to build. Time to finish the job.
jorj-bauerJorj Bauer 03/02/2015 at 13:160 Comments
Although two different people have reverse engineered the wireless protocol used by these wireless temperature sensors, they've both ignored the checksum. While that's fine from the perspective of "at least I got the data out," it's not good enough for me. RF is messy; checksums are useful. I'd like to understand what the checksum is, so that I'm relying on more than just parity bits.
First stop: assuming it's a CRC.
Plain CRCs obey a mathematical constraint -- if you XOR the plaintext by a given value, that causes a specific XOR change to the output. So if data (D) is modified by (A) to generate CRC (C) with modifier (B):
D1 ^ A1 = C1 ^ B1
D1 ^ A2 = C1 ^ B2
Then it should also be true that
D1 ^ A1 ^ A2 == C1 ^ B1 ^ B2
If that relationship doesn't hold, then it's not a standard CRC implementation.
Well, I picked three messages, determined their xor'd differences, and found that this relationship was true for those messages. So I spent a couple of hours trying to divine what the polynomial might be, on which that CRC is based.
As a quick aside: I stumbled across RevEng http://reveng.sourceforge.net/ - which I'd not previously seen. Looks interesting.
Sadly, that was all a red herring. I finally decided I should take a look at other checksums, and starting with what I thought would be the simplest one - a modular checksum - I found that the checksum on these packets is no more than adding up all of the bytes in the packet.
Wow, what a waste of time. :)
I'm baffled by the combination of parity bits (as the high bit of each byte) and a simple modular sum byte at the end. A typical modular checksum uses the two's complement of the added bytes, so that the implementation can just add up all of the bytes of the packet, and expect to get a final result of 0. This implementation seems to just make more work for the receiver. It feels a lot like it was implemented by someone that had little experience with RF protocols.
