ESP8266 migration complete
09/18/2016 at 15:28 • 0 commentsBluetooth has now been completely exorcised as the DHT22 and DS18B20 toting version of the sensors has been upgraded into a NodeMCU module.
ESP8266 migration
09/15/2016 at 09:25 • 0 commentsReplaced the sensors carrying only a DHT22 with ESP8266-01 versions communicating through MQTT. Seems to be rock-steady after adding a capacitor to ensure steady power to the ESP.
The third sensor needs more pins for the two temperature sensors, so it has to be made with an ESP-12 or a NodeMCU board. Which I happen to have.
Pebble dashboard
03/13/2016 at 07:33 • 0 commentsIt's quite fast to make an HTTP API connected Pebble app using the pebble.js framework and the Cloudpebble browser IDE, so I made a dashboard app that provides a similar view into the measurement data as the web dashboard.
The app shows the current values for each sensor in a menu UI and each item can be drilled into for information on the previous measurement and the time of measurement.
ESP8266
08/16/2015 at 20:17 • 0 commentsBuilt a prototype for a DHT22 and standalone ESP8266 (ESP-01) combination. Sensor values are transmitted through the MQTT server. Works quite nicely although the ESP got mysteriously stuck on one test run after a couple of hours.
Sensor upgrade
04/11/2015 at 10:00 • 0 commentsConsidering replacing the HC-06 modules with ESP8266. The Bluetooth connection is extremely prone to failing. Even a slight change in the placement or orientation of the sender or receiver can cause a huge difference in reliability.
Also this change would get rid of the node.js middleman which is a huge bonus.
