The time consuming part was sewing on the EL wire. The power pack sat in the inside chest pocket, and I cut small holes to feed the wires into the jacket lining. I used clear nail polish on the holes to stop them from fraying. Luckily the fabrics were thick enough so that the EL wire didn't show through.
Jasmine Brackett
Roger
leadacid44
ThinkLearnDo
I was recently hit by a car as a pedestrian and would really like to start implementing lighting into my fashion. Some people may not find your documentation to be containing enough details and categorical reasoning which helps to narrow the scope of focus correctly through the iterative steps of your recipe to lead them to the desired end result. For those who are passionate about technology, that is painful. I would like to help by writing better documentation for those who need it, could you help me help you by sending a kit? Currently flat broke, and naturally in student debt.
