ESP32S Devkit - Eagle Library
A project log for Muffsy Stereo Relay Input Selector
Open Source, versatile audio relay input selector controlled by an ESP32
skrodahlskrodahl 02/04/2018 at 22:3810 Comments
I couldn't find the footprint for the ESP32S Devkit anywhere, so I made my own.
You'll find it in the files section.
Emerson-Nunes wrote 05/03/2021 at 22:03 point
Thank you very much! It helped me a lot!
Herwig Bachner wrote 03/28/2021 at 15:52 point
Hi, Sorry ignore my last post. Everthing ok, my fault, I found it. Thanks for the lib, it saves me a lot of work.
Herwig Bachner wrote 03/28/2021 at 15:17 point
Hi, please could you check the download files. There is an entry for the ESP32 Eagle Library , but the download content is something about a relais curcuit, not the Eagle lib.
Luigi Gadotti wrote 03/26/2021 at 09:12 point
help me please... i don't know where i can download lib
tidaktahubulat91 wrote 02/18/2023 at 08:01 point
https://hackaday.io/project/46280/files
predatorkiller wrote 02/25/2021 at 22:04 point
i dont see download button. pls check
tidaktahubulat91 wrote 02/18/2023 at 08:02 point
Filipe "Ender" Araujo wrote 09/08/2020 at 21:24 point
Thank you, this will help me a lot!
michoteuber wrote 10/25/2019 at 14:12 point
donde lo descargo?
ThorstenNRW wrote 03/25/2019 at 14:34 point
I used your library. But after board manufacturing in China, I realized the distance between both pin rows is 100 mil ( = 2.54 mm, or 1/10 inch) too small. How does this come? I use the Devkit V4. Have earlier versions been smaller?
