All to do with table saws
Will continually add still pictures of all the updates and ideas for table saw safety
This is the Original Jimmy Jig, the first big change to the sliding t- fence on a table saw
macduff/ fixed the fence to a sliding support platform
will cross-cut 8ft sheet material with the use of the outrigger which has but one line of friction along the top of the round pipe
JPEG Image - 3.74 MB - 02/04/2018 at 21:48
Preview
simple if you think about it
JPEG Image - 3.53 MB - 02/04/2018 at 21:47
Preview
The jimmy jigs lift off guard, central pivot is automatic
JPEG Image - 2.75 MB - 02/04/2018 at 21:44
Preview
very simple cross-cut -sled on the Jimmy Jig
JPEG Image - 3.33 MB - 02/04/2018 at 21:43
Preview
Jimmy jig in Spanish
JPEG Image - 3.15 MB - 02/04/2018 at 21:41
Preview
View all 32 files
  • 1 × the jig Originally used plywood, now updated to a professional model using the very same details
View all 14 project logs
  • 1
    Step 1
    The jimmy jig/ used 1/2in ply cover with laminate both sides, hardwood telescoped rails, or 20/80 aluminium extrusions and a clamp that forces the jig rails against the frame that surrounds the table saw/ rock solid, the fence will never deviate from parallel as it it fixed to the sliding platform, In the unique aperture of the jig you can add a router or jig saw in an extra insert, these inserts are also a zero clearance over the blade
View all instructions
seilerjacinda925 wrote 11/19/2019 at 15:43 point
Hi
Nice to meet you after viewing your profile i am Jacinda, from (jakarta) indonesia,
i have a project discussion with you please email me on: (jacinda.seiler@yahoo.com)
macduff2 wrote 02/04/2018 at 22:03 point
invite all table saw owners to discuss the Jimmy Jig , pros or cons
