Wiring the Module for Power and Control
A project log for Mike's Robot Dog
Boston Dynamics' robot dog, Spot Mini is unavailable at any price. A Chinese copy is $30,000. Cut 99% of the cost and build one at home.
Mike RigsbyMike Rigsby 05/24/2018 at 19:552 Comments
To make the module stand requires power and control. Here's a schematic of the power components.
Let's look at the physical wiring. I connected the + and - power blocks using number 18 stranded wire.
I added an Arduino Uno to control the servo motors.
Pins 0 through 11 are connected as follows:
A top view of the connected wiring is shown below.
The starting position for the servo motors on the legs is shown below.
Because each spline on a servo shaft/horn represents about 15 degrees, the servo motors must be operated until a satisfactory position is achieved and that value should be recorded.
The .ino Arduino sketch for standing/sitting on this site as module test 0524.
Here's the standing routine.
Mike Rigsby wrote 05/25/2018 at 20:10 point
You are correct--I really haven't worked out the onboard power supply yet.
deshipu wrote 05/25/2018 at 07:25 point
Very neat cabling! I always have problems with that. One note, though — I would connect the capacitors after the switch. They always have some leakage current, and might drain your battery if left switched off for a long time.
